Use the following commands to display information on one or all VMANs.
show {vman} vman_name {ipv4 | ipv6}
show vman [tag tag_id | detail] {ipv4 | ipv6}
show {vman} vman_name eaps
The display for the show vman command is different depending on the platform and configuration you are using. See the Switch Engine v33.1.1 Command Reference Guide for complete information on this command.You can also display VMAN information, as well as all the VLANs, by issuing the show ports information detail command. And you can display the VMAN ethernet type and secondary etherType port_list by using the show vman etherType command
